ajkron
Dec 14, 2018Guide
night hawk xr500 slow speeds all of the sudden
wireless speeds were great then all of the sudden they went down to 30-40. was getting 300 plus. when i connect to my modem i can achieve 300plus. i am on uverse gig service. i have tried all the...
- Dec 15, 2018You should get 3 months support with them I think.
A possible trick is to give the XR500 the MAC address of your previous router. Sometimes the ISP has trouble negotiating with a new router in which case that fixes it in some cases.
ajkron
Dec 14, 2018Guide
FURRYe38 wrote:
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
FW 2.3.2.40
Mfr and model# of the ISP modem: pace 5268
connecting on auto but have tried various channels with no success
roughly 10 wifi neighbors nearby
have 2 unverse tv's hooked up to my uverse modem. thats the only thing plugged into isp modem due to the fact that it buffers if i plug into nighthawk
ajkron
Dec 14, 2018Guide
this is getting a little frustrating to say the least. now my router speeds are showing 42 down and 360 down. any input would be greatly appreciated.
- FURRYe38Dec 15, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.Also review this about PACE FW:
- Netduma_JackDec 15, 2018NetDuma PartnerDo you get full speeds into the modem?
Also make sure your QoS settings are optimised for
Max bandwidth speed:
http://support.netduma.com/support/solutions/articles/16000076586-dumaos-optimal-settings-guide-maxmimum-bandwidth-speeds- ajkronDec 15, 2018Guide
i do goet full speeds on the modem. i have attached screen shots of my speeds with my modem and router. rolltide network is my isp modem and rolltide2 is the nighthawk. i have tried the QoS settings in the link and the results are the same. i contacted my isp and they told me i am in bridge mode.
