Wangazchick
May 02, 2020Tutor
Night hawk xr500
Hi Help PLEASE I can not set up my new router to my PlayStation for streaming and gaming keeps lagging
Wangazchick
May 02, 2020Tutor
Hi I have 2 PlayStation connected through wifi my ping is about 30 to 50 my internet speed is download sits around 80 upload is about 20 I have the xr500 connected to a lan port in my modern my modern connected too an nbn box
Thank you
Hope this helps
Thank you
Hope this helps
Netduma-Fraser
May 03, 2020NetDuma Partner
That ping is fine - is that the game ping shown by the Geo-Filter? What is the trouble you're having exactly? What QoS/Geo-Filter settings are you using? You would likely have a better ping if you connect the PS4s via ethernet.
- WangazchickMay 03, 2020TutorHi on the night hawk we only have 3 ps4 running off the router an all the phones are running off my moderm soon as my son starts streaming we all start to lag that Ping was on console not the geo-filter we running call of duty profile settings we used TECH HD on YouTube for a guide too set up due too not knowing what to do we also had my self an son running from the moderm and my partner from the Router an only my partner was lagging
Thank you- FURRYe38May 06, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
Thank you- Netduma-FraserMay 06, 2020NetDuma PartnerLet us know how you get on fine tuning with that guide. If it still continues you may need to disable DumaOS Classified Games in Traffic Prioritization and see if that helps further.
- WangazchickMay 03, 2020TutorHey we are based in Australia
- Netduma-FraserMay 03, 2020NetDuma PartnerYou need to connect all devices to the router otherwise it can't control the devices properly to eliminate lag. Do that first and then your QoS settings should prevent that from happening.
- WangazchickMay 03, 2020TutorAwesome Ill check now thank you
