Lewisbeardmore
Nov 18, 2019Follower
Night hawk??
Is it worth getting one if I only get 37-44 mbps? Will this get it up or will it stay around the same as it is now??
Nov 18, 2019Guru - Experienced User
To little info to be able to tell you.
1. Are you cable/dsl/fibre? Whats providing service to you?
2. What speeds are you paying for?
3. Modem you're using?
4. Device you're testing on?
5. Testing over wired, wireless? which band?
6.Website testing with?
Get what I'm going after? To truly tell you if you can get better speeds with an update requires to us know what your current bottleneck (slow down) is.
