Syt7
Jul 13, 2023Follower
Nightgear XR500 Crashes/Restarts when Large Wifi Download
Hello everyone. I have an issue with my XR500 which has started happening around 6 months ago intermittently. Background: I have a 100Mbps line in from Virgin Media using the superhub as a simpl...
Jul 13, 2023Guru - Experienced User
Does this happen if the game consoles are ethernet connected to the router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is Armor enabled on the router?
Does this happen after a factory reset and setup from scratch and don't use PiHole configuration?
