Syt7
Jul 13, 2023Follower
Nightgear XR500 Crashes/Restarts when Large Wifi Download
Hello everyone. I have an issue with my XR500 which has started happening around 6 months ago intermittently. Background: I have a 100Mbps line in from Virgin Media using the superhub as a simpl...
Netduma-Fraser
Jul 13, 2023NetDuma Partner
Definitely not a common issue and will be harder to diagnose if the log isn't showing anything/cleared after a reboot. One thing it could be though - do you have the XR500 connected to a power extender or direct to a wall outlet? If an extender try direct, do you get the same issue then?
