jer22
Mar 23, 2022Aspirant
NightHalke XR500 - reboot every 2-3 weeks needed
About every 3-4 weeks, the TV (Hulu) delays streaming as well as other slow ups. I just wind up rebooting the router and everything is fine for another period of time. It's almost as if some memory o...
jer22
Thanks for the reply.
Yes - In hulu the signal stops for a bit, there is a small spinning wheel on the Hulu timeline and then continues. If I do a speed test with WiFi from my iphone, often times that seems to "trigger" the signal to continue. It seems eventually Hulu says it cant see an internet connection. Then if I check my WiFi, it has dropped the internet connection as well. If I go directly to the spectrum modem, it hums along - it is still connected to the internet as is the other Router on the Spectrum device's 2nd ethernet port. Its only the XR500. And once I reboot it, everything seems to work for again, about 3-4 weeks.
Netduma-Fraser
Mar 23, 2022NetDuma Partner
When it happens again could you access the System Information page on the router and take a screenshot of what you see please? It would also be helpful if you could grab the log file from that same page as well.
