jer22
Mar 23, 2022Aspirant
NightHalke XR500 - reboot every 2-3 weeks needed
About every 3-4 weeks, the TV (Hulu) delays streaming as well as other slow ups. I just wind up rebooting the router and everything is fine for another period of time. It's almost as if some memory o...
jer22
NIGHTHAWKE - I corrected it. Typing fast. (kind of like "connected too" in your message)
is there another XR500?
the latest firmware - I look for update and it says there are none.
It just says UBEE on the modem. It actually has four ethernet ports on the back. Two seem useable. So that's what I have to use.
I do not have problems all the time, which I figure would happen if there was a problem with double NAT. IT is only after a period of time - originally I said 3-4 weeks. It is still 3-4 weeks
Mar 24, 2022Guru - Experienced User
When this happens does the Internet LED turn amber by chance?
Can you find a model# of the ISP modem on the modems sticker?
