Rambo111003
Jun 21, 2019Aspirant
Nighthaw x6 R8000 offline setup?
Hi there! my ips recently blocked me from using my wifi without inputting there settings and i recently factory reset my wifi so i need to visit routerlogin.net. but my router cant connect because it wont work without internet. is there any way to bypass this step in the setup? thanks for your help :)
1 Reply
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
Rambo111003 wrote:Hi there! my ips recently blocked me from using my wifi without inputting there settings and i recently factory reset my wifi so i need to visit routerlogin.net. but my router cant connect because it wont work without internet. is there any way to bypass this step in the setup? thanks for your help :)
