Stretch163
Jun 26, 2019Aspirant
Nighthawk 500 gaming
Hi all not usually slow at connecting things but having problems with my Thailand AIS setup to connect to my Xr500. From my supplier I have 2 x boxes. First box is small box with fiber in connec...
Jun 26, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? If so, Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
Netduma-Fraser
Jun 26, 2019NetDuma Partner
Just to clarify, your ISP doesn't provide internet via a wireless connection as looking up Thailand AIS brings up services like that.
