Misterswede
May 24, 2019Guide
Nighthawk 700
I have tested cat 5e, cat6, cat6a,cat7 ps4 pro shows white led in port I understand that is gigabit epson tw9300 4K projector with gigs card inside shows red in port samsung kbd8500 4K player with...
May 24, 2019Guru - Experienced User
Whats the model of the NG router? XR700?
https://www.downloads.netgear.com/files/GDC/XR700/XR700_UM_EN.pdf
Ethernet ports 1-4
The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.
• Solid. A powered-on device is connected to the Ethernet port.
• Blinking. The port is sending or receiving traffic.
• Off. No device is connected to this Ethernet port.
- MisterswedeMay 24, 2019GuideBrand new XR700 and latest firmware
Yes PS4 has white and Epsom and 4K player amber
Tested with all cables- FURRYe38May 24, 2019Guru - Experienced User
Well if one device reports 1000mb and the others don't, possible connection issue at those devices. I persums you've swapped ports around as well.
I would contact the Mfr of those devices to check on connection rate support...
- MisterswedeMay 24, 2019GuideMany thanks I will
