Misterswede
May 24, 2019Guide
Nighthawk 700
I have tested cat 5e, cat6, cat6a,cat7 ps4 pro shows white led in port I understand that is gigabit epson tw9300 4K projector with gigs card inside shows red in port samsung kbd8500 4K player with...
May 24, 2019Guru - Experienced User
Whats the model of the NG router? XR700?
https://www.downloads.netgear.com/files/GDC/XR700/XR700_UM_EN.pdf
Ethernet ports 1-4
The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.
• Solid. A powered-on device is connected to the Ethernet port.
• Blinking. The port is sending or receiving traffic.
• Off. No device is connected to this Ethernet port.
Misterswede
May 24, 2019Guide
Brand new XR700 and latest firmware
Yes PS4 has white and Epsom and 4K player amber
Tested with all cables
- FURRYe38May 24, 2019Guru - Experienced User
Well if one device reports 1000mb and the others don't, possible connection issue at those devices. I persums you've swapped ports around as well.
I would contact the Mfr of those devices to check on connection rate support...
- MisterswedeMay 24, 2019GuideMany thanks I will
Let us know what you find out.
