Misterswede
May 24, 2019Guide
Nighthawk 700
I have tested cat 5e, cat6, cat6a,cat7 ps4 pro shows white led in port I understand that is gigabit epson tw9300 4K projector with gigs card inside shows red in port samsung kbd8500 4K player with...
Misterswede
May 24, 2019Guide
Brand new XR700 and latest firmware
Yes PS4 has white and Epsom and 4K player amber
Tested with all cables
May 24, 2019Guru - Experienced User
Well if one device reports 1000mb and the others don't, possible connection issue at those devices. I persums you've swapped ports around as well.
I would contact the Mfr of those devices to check on connection rate support...
- MisterswedeMay 24, 2019GuideMany thanks I will
- FURRYe38May 24, 2019Guru - Experienced User
Let us know what you find out.
