Jfosterjrod58
Dec 26, 2018Aspirant
Nighthawk ad7200, X6S mesh extender, specs for ethernet ports please
I am about to network my new Nighthawk ad7200 router and X6S mesh extender. They will have considerable obstacles in between them that may cause interference in the wifi signal. I am considering to h...
Jfosterjrod58
Dec 27, 2018Aspirant
If you are going to reply anyway, how about just answer the Q...
Dec 27, 2018Guru - Experienced User
IM sure someone will help you out when you post in the correct forum.
Good luck.
