mrekimf
Apr 12, 2019Apprentice
Nighthawk Android app no devices connected?
I recently bought the XR500 router. Its been 3 days since I've had it, but dont think it has anything to do with it. Just got the range extender EX7700, seemed to be working. Then I tried connecting my Garage door Geni through wifi and was having problems. So I turned off the extender. Now when I check my Nighthawk app, I have no devices connected according to the app, but I can count at lest 12 devices currently connected. I have checked for current firmware, uninstalled then reinstalled the app, and no change?
Any ideas?
Please post about this here in this forum:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
- mrekimfApprentice
Well thats where I started, then someone said to move it here. So unless its a moderator, telling me to move it, I aint moving it. Apparently no one else has this issue.
- Netduma_JackNetDuma Partner
I'd recommend creating a new thread in the App area, as the Nighthawk Pro Gaming area is focussed on the routers use themselves (pretty much anyway).
Might be worth getting in touch with official NETGEAR support too.
The ethernet connection will be only as good as the wifi connection between the XR500 and the EX7700 is.
- mrekimfApprenticeGot it, so no difference in using ethernet or wifi.
Thanks
:smileywink:
