mrkymrk01
Sep 14, 2020Follower
Nighthawk App not updating devices with xr500
Router Firmware - XR500 V2.3.2.56 App: Nighthawk App Version: 2.6.2.1242 Operating System: Android (Galaxy S8, model SM-G950U) Androis OS Version: 9 When using the mobile app (over wifi, conn...
michaelkenward
Sep 20, 2020Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I have asked the Netgear moderator to move your message.
Netduma-Fraser
Sep 20, 2020NetDuma Partner
I don't think that is a firmware issue given it is done on the app. If you change the name/type on the router interface does that work?
