arewe3
Nov 02, 2025Aspirant
Nighthawk AX4 in AP mode connect to XR300
I hope this is the correct place to post this. I have a XR300 router. I have connected it with a LAN cable to AX4 router that I setup in AP mode. The XR300 will not connect to the AX4 router. (My...
- Nov 07, 2025
arewe3 wrote:
I might look at going with a wireless solution because the cable will be very hard to replace.
How much speed do you actually need in this building? How many people are using the internet there at the same time? 100 mbps is slow for copying really large files, but it is ok for web browsing, email, wifi calling, and even video conferencing and streaming. So one option is to just live with fast ethernet speeds.
On replacing the cable - It might be easier to run a new cable (perhaps in another conduit) than to replace the old one. Though that depends on what else is in the conduit. If it is only the one cable, then it might be possible to pull a new cable through it (attaching a thinner nylon cord to the existing cable, pulling the existing cable out - leaving the cord in the conduit, and then pulling the new cable using the nylon cord). There are several youtube videos on this topic that you could explore. Another option (requiring ethernet transceivers on both ends) would be to pull fiber, which is thinner.
As far as wireless goes - there are point-to-point wifi solutions that can be used as a substitute for the cable (one unit on each building, with line-of-sight between them). I doubt you'll get gigabit speed, but you likely can get something faster than 100 mbps.
CrimpOn
Nov 02, 2025Guru - Experienced User
RAX35, user manual page 90:
arewe3
Nov 03, 2025Aspirant
I connected the main XR300 router from local ethernet port #1 to the RAX35 router (in AP mode) to the yellow port (WAN). Still do not get a connection. the XR300 lights that show which LAN ports are active is still blinking amber every 5 seconds.
Not sure is helpful but the other thing I noticed last night is when I am in the device manager on the XR300 it shows a network diagram of what is connected. I see a symbol that says "Offline". I assume it is my RAX35 because it shows that my garage cameras and other things are connected to it. When I select my camera it gives me the MAC address however it does not have an IP address. I assume the "offline device" showing in the diagram is my RAX35 in AP mode. If I disconnect the data cable from the XR300 that goes to the RAX35 the "offline device" still shows up in the network diagram with all of my wireless equipment connected to it.
Thanks for helping with this issue.
