grahamer
May 04, 2021Aspirant
Nighthawk ax5400 xr1000 bandwidth mbps capped pc gaming traffic wifi 6
Netgear Nighthawk speed test comes back with ~980 mbps download speeds. All devices LAN (Eth) or Wifi get normal download speeds when viewing media, downloading content, streaming etc. When a game ...
Netduma-Fraser
May 07, 2021NetDuma Partner
Where are you testing the speeds where you see it drop like this? What QoS settings were you using and how did you disable QoS exactly?
- grahamerMay 07, 2021AspirantI tested with qos on and off. I prioritized traffic by device and application. Im monitoring the speed in the Network Monitor tab. Evrything works fine wired and wireless unless its game data traffic. Any device running gaming traffic only pc or console will get scaled back to .2mbps.
- Netduma-FraserMay 08, 2021NetDuma PartnerAhh I see. Gaming doesn't use a lot of bandwidth at all, it's not being throttled, that is just how much it is actually using, so it's all fine
- grahamerMay 08, 2021Aspirant
Thats what i was thinking. I couldnt find anything on the web that show how much bandwidth is used in actual multiplayer games. I assumed when p[aying there would be spikes depending on the situation. My ping is fine most of the time, latency is fine and no packet loss. It seemed that people were a couple of steps ahead of me once i bought my own gear (modem and router). Can you confirm your bandwidth speeds in game? Thank you!
- Chirx88May 08, 2021Aspirant
Hi! Might be something simmlair..
I am having XR1000, not in moddel list for some reason, but thing what i am expieriencing is, one of my TV`s after reboot couple h works good (TV TCL wifi n standart), then turn it off and come back after couple h and network speed is really terrible like 10kbits/s and can`t even use youtube or netflix, but internet speed is stable 400+mbit/s other devices works good and quick, instantly loads whatever you need.. After restarting again woorks good reaching spped of 35mbit/s, instantly loads everything, after couple h off same problems again...
Been using this device with previous asus ac router no problems, also with built in isp wifi no problem..
Tryed reseting to defult settings, messing around with other settings ends up at same problem at first works good then stops...
Any Ideas how to fix?- Netduma-FraserMay 08, 2021NetDuma PartnerChirx88 when you turn it off is it still in standby mode or is it off fully? I suspect it will be because it was in standby mode that is why it happened
