Co2Outbr3ak
Jul 03, 2019Aspirant
Nighthawk C7000 Upload Speed Problem on Xbox One X
So I'm at my ends here. For some reason, my Xbox One X's (2) can't seem to hold an upload speed when using this device. Both devices are hardwired to the modem, as well as a hardwired PC. The PC has ...
Jul 03, 2019Guru - Experienced User
If everything but the xbox's hit the speed requirement, I'd be inclined to believe it isn't the modem/router device. A quick search on google showed many people with slow upload speeds on xbox one x's. I'd try posting on that forum to see if anyone has idea's/settings changes on the xbox or what can be done to help.
- Co2Outbr3akJul 04, 2019AspirantThat's the thing tho. It's been fine with these systems for well over a year....I mean, I'd doubt a problem with the systems is doing it, but I could probably post on Xbox forums and see if they have any ideas as well. Like I said, it happened suddenly and hasn't fixed since (about a month or so).
- plemansJul 04, 2019Guru - Experienced User
The c7000v2 firmware is all ISP controlled and rarely updated for this fact. the xbox firmware/software comes from microsoft and is going to receive many more updates and changes. If its worked fine in the past, these updates/changes to the xbox are more likely to be causing the issue. Again, I'd look to those forums for settings changes to the xbox that could be causing this issue.
