Co2Outbr3ak
Jul 03, 2019Aspirant
Nighthawk C7000 Upload Speed Problem on Xbox One X
So I'm at my ends here. For some reason, my Xbox One X's (2) can't seem to hold an upload speed when using this device. Both devices are hardwired to the modem, as well as a hardwired PC. The PC has ...
Co2Outbr3ak
Jul 04, 2019Aspirant
That's the thing tho. It's been fine with these systems for well over a year....I mean, I'd doubt a problem with the systems is doing it, but I could probably post on Xbox forums and see if they have any ideas as well. Like I said, it happened suddenly and hasn't fixed since (about a month or so).
Jul 04, 2019Guru - Experienced User
The c7000v2 firmware is all ISP controlled and rarely updated for this fact. the xbox firmware/software comes from microsoft and is going to receive many more updates and changes. If its worked fine in the past, these updates/changes to the xbox are more likely to be causing the issue. Again, I'd look to those forums for settings changes to the xbox that could be causing this issue.
