scribz23
Aug 06, 2019Guide
Nighthawk gaming router wifi connection issues. Will connect to phones and laptops but not others.
Set my router up and it is working fine through ethernet connections to my desktop and wirelessly to phones and laptops but it will not connect wirelessly to desktop computers, xbox, or roku at this ...
- Aug 08, 2019
On the wireless setup page disable SSID broadcast for both 2.4GHz and 5GHz. Then also on the Advanced WiFi settings page disable Wireless Router radio.
Netduma_Alex
Aug 07, 2019NetDuma Partner
Make sure that you didn't set static IP addresses on those devices
- scribz23Aug 07, 2019Guide
would that be on the actual xbox and roku?
- Netduma-FraserAug 07, 2019NetDuma PartnerNo that would be on the router itself. I would suggest disabling smart connect first as it doesn't seem to play nice with all devices, if it doesn't work you'll need it disabled anyway to do the channel suggestions from above.
