scribz23
Aug 06, 2019Guide
Nighthawk gaming router wifi connection issues. Will connect to phones and laptops but not others.
Set my router up and it is working fine through ethernet connections to my desktop and wirelessly to phones and laptops but it will not connect wirelessly to desktop computers, xbox, or roku at this ...
- Aug 08, 2019
On the wireless setup page disable SSID broadcast for both 2.4GHz and 5GHz. Then also on the Advanced WiFi settings page disable Wireless Router radio.
scribz23
Aug 08, 2019Guide
how do you completely disable the wireless? I do not see an option for that.
Netduma-Fraser
Aug 08, 2019NetDuma Partner
- scribz23Aug 08, 2019Guide
That worked!! I also redisabled the guest wifi and changed the password back to the original after testing to see if it worked and it still does. Confusing to me but it works now and thats what matters. Thank you very much for you help!!
- Netduma-FraserAug 10, 2019NetDuma PartnerFantastic to hear that, you're very welcome!
