Thorlake
Aug 15, 2018Tutor
Nighthawk has stopped Broadcasting Wifi
Hi,
Installed the XR500 and it initially worked flawlessly...for a couple of days. First the 5GHz Wifi network disappeared but the 2,4GHz stayed up. But now both have gone. It is also only the ...
Netduma-Fraser
Aug 15, 2018NetDuma Partner
Have you enabled the option to hide SSID broadcast?
- ThorlakeAug 15, 2018Tutor
Yes, I even disabled it, did an "Apply" and then Enabled it again too see if it did anything. But nope.
- Netduma-FraserAug 15, 2018NetDuma PartnerDouble check thats still disabled after your last test, then disable beamforming and mumimo and see if you can see it
Sorry to say, that did not help either. (I restarted the router also.)
Noticed also that the white LED for the 2,4GHz is also flashing steadily like once every second. (5GHz LED still black).
