Thorlake
Aug 15, 2018Tutor
Nighthawk has stopped Broadcasting Wifi
Hi,
Installed the XR500 and it initially worked flawlessly...for a couple of days. First the 5GHz Wifi network disappeared but the 2,4GHz stayed up. But now both have gone. It is also only the ...
Thorlake
Aug 15, 2018Tutor
Yes, I even disabled it, did an "Apply" and then Enabled it again too see if it did anything. But nope.
Netduma-Fraser
Aug 15, 2018NetDuma Partner
Double check thats still disabled after your last test, then disable beamforming and mumimo and see if you can see it
