Kmak_Mak
Nov 09, 2021Follower
Nighthawk Pro console gaming bandwidth fluctuation
Hello, I just bought the XR1000 primarily to stabilize the connection on my Xbox Series X. After installing it today, I realize that the benchmark speed test on the router came up as: Download 800 Mb...
Netduma-Fraser
Nov 09, 2021NetDuma Partner
Console speed tests are not always accurate, if you're getting your speeds through a PC speedtest that's the most important. If the console needs all your speeds it will be able to take it.
