igobyandrew
Nov 16, 2020Aspirant
Nighthawk Pro Gaming XR450 connectivity issues
I'm having issues with my Nighthawk Pro Gaming XR450 that I purchased from Costco about two years ago. On my network, I cannot connect to sites like Disney+, Hulu, Amazon Prime, or certain game s...
Netduma-Fraser
Nov 16, 2020NetDuma Partner
Go to the QoS page and disable QoS completely from the Anti-Bufferbloat 3 line option menu in the top left of the panel and see if that helps please. QoS may be dropping packets unnecessarily.
- igobyandrewNov 17, 2020Aspirant
Thanks! I disabled it as suggested and it seemed to have solved a lot of the issues. Still not getting certain things to stream online though. Firmware is also updated to latest.
thanks!
