Am97028
Mar 31, 2022Aspirant
Nighthawk pro gaming xr500-100nas router No internet after power disruption
After a power failure, my router does not have internet connection. I need to unplug router for 15 seconds then power it back up for it to work. Since my security cameras need the internet to work, I ...
Mar 31, 2022Guru - Experienced User
There isn't a built in way.
But a half decent power supply to put them on might be a good option for next time.
You might be able to call your ISP and have them remote reboot (or even through their online portal?) the modem.
Maybe if the router is already booted and the modem reboots, it might pull a new ip address. (might take a bit though)
- Am97028Apr 01, 2022Aspirantplemans
I could keep my modem on a ups to weather the storm. The issue is when they both boot together or when I just reboot the modem.
Thank you.- FURRYe38Apr 01, 2022Guru - Experienced User
I've also noticed this when I bring my XR450 online. After power cycling the ISP modem, the XR fails to connect until the XR is rebooted afterwards once more, then the XR connects. Been like this since I got it. Not sure if this was intended or is a bug. I would consider this a bug as other NG routers don't exhibit this issue.
