Am97028
Mar 31, 2022Aspirant
Nighthawk pro gaming xr500-100nas router No internet after power disruption
After a power failure, my router does not have internet connection. I need to unplug router for 15 seconds then power it back up for it to work. Since my security cameras need the internet to work, I ...
Netduma-Fraser
Apr 01, 2022NetDuma Partner
No not specifically unfortunately, the only suggestion I could give for when this happens would be to get a modem/router instead of the EU2251 if possible. Then connect that to a smart plug, have the XR500 on a separate smart plug with both smart plugs connected to the modem/router. That way you could reboot them separately remotely, in which case reboot the modem, wait 2 minutes then reboot the XR500.
Am97028
Apr 01, 2022Aspirant
Netduma-Fraser
I thought of that. I could use the xr500-100nas as an extender then. I was just wondering if you were familiar with this models settings. I thought there might be a setting that would slow down the boot process if that was possible.
- Netduma-FraserApr 01, 2022NetDuma PartnerThere is not unfortunately, sorry to say!
- Am97028Apr 01, 2022AspirantThank you.
