wardemon
May 29, 2019Follower
NIGHTHAWK PRO GAMING XR700 support Mesh
Hey i just got the XR700 as a gift, but i am affraid that the coverage of the wifi wont be enough does the router support mesh networking? can i buy another XR700 and connect them togither? or an...
May 29, 2019Guru - Experienced User
No. MESH is reserved for the Orbi system.
You could connect a NetGear EX8000 to the XR as an extender for additional wireless coverage and range.
- Netduma_AlexMay 29, 2019NetDuma Partner
No unfortunately mesh isn't currently supported.
