c0y0te7
Dec 14, 2022Follower
Nighthawk Pro XR500 Gaming Router - has started constantly changing lease which is causing issues
Hi folks, My XR500 has been pretty stable for years (purchased in 2020) but in recent days has started doing mad things and from the logs it looks like it's renewing/releasing the lease a lot mor...
Netduma-Liam
Dec 14, 2022NetDuma Partner
Could you please go to Settings -> Setup -> LAN Setup and set the minimum DHCP value to .100.
Then, go through the table below it and reserve an IP address for each device on the network. Give each device an IP from .2 to .99.
After that, see if you still have issues with disconnections.
