SHale0824
Apr 13, 2020Follower
Nighthawk R6900v2 Slow Speeds
Testing my routers speed from my app it is recieving 140-170 mbps download speeds. I updated the firmware and the current version is v1.2.0.62_1.0.1 I factory reset my router and turned off s...
Apr 13, 2020Guru - Experienced User
What modem are you using? (brand and model)
How are you testing speeds? Game servers aren't reliable speedtest sites.
look at speedtest.net or dslreports.com to test speeds.
