GianniAmerican
Feb 19, 2019Follower
Nighthawk R8000P reset automatically
My Nighthawk R8000P reset automatically to the default SSID for each chanel, all without any security. Anyone else have this issue today, or at all? Not sure if this is normal behavior following some sort of firmware update, or if there is a bug, or a security vulnerability. Please help. Thanks.
1 Reply
You'll need to post about this in this forum for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
