Smash_oli
Jul 28, 2019Aspirant
Nighthawk R9000 Ap Mode
Hi, Nighthawk R9000 in AP Mode, how does it deal with physically connected devices? If you connect a device to the AP will it just hand all traffic back to the router to then send back to the AP...
Smash_oli
Cheers Kurt,
I'm hopefull this will work then as I know like you say the ethernet ports do work when in AP mode and in the advanced settings anything not available is greyed out when in AP mode, link aggregation is not greyed out, so with your explanation of it still utilising l2 not l3 routing I reakon I'm good to go.
Will try it out.
Best Regards
Oli
Will try it out.
Best Regards
Oli
Jul 28, 2019Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
Smash_oli wrote:
Cheers Kurt,
Will try it out.
Best Regards
Oli
