SychoOverkill
Jun 03, 2019Follower
Nighthawk rx300
Hi. New to the gaming router when I first plugged everything I had fast speeds to my ps4 and now the speeds are and everything has dropped can barely get into games does anyone know the fix for that?
Jun 03, 2019Guru - Experienced User
Is the game console wired or wireless connected to the XR router?
Do you get good speeds with a wire connected PC?
Netduma-Fraser
Jun 05, 2019NetDuma Partner
What were the speeds on the PS4 and what are they now? Console speed tests can be inaccurate, if you do a speed test on a wired computer what results do you get? Gaming requires very little bandwidth so it is unlikely that is the cause of the issue - what game are you playing and are you using the Geo-Filter?
