Wyzfar
Nov 06, 2018Aspirant
nighthawk speed test
Hello so whenever doing a speed test on the nighthawk xr500 while doing a network setup it says bandwidth test failed and my download Speeds look about normal but it sets my upload at 1000 mbps uploa...
Nov 07, 2018Guru - Experienced User
What FW is currently loaded?
What ISP speeds do you pay for UP and Down?
Netduma_Jack
Nov 07, 2018NetDuma Partner
To add to this - I believe Speedtest, who NETGEAR use to run this test, have had a few server problems lately which has affected this. Perhaps try running it again now and see if it's working (you will need to factory reset to reinitiate this test).
Don't worry if you would prefer not to, manually entering in your speeds is more than sufficient.
- WyzfarNov 07, 2018AspirantI just reset my router last. Ugly had anything server related changed within the last 24 hours? - and whenever I dedicate speeds like let’s say 200 download to my ps4 it’s not consistent
- Netduma_JackNov 08, 2018NetDuma Partner
When you allocate 200mbps bandwidth to a device - it will only take 200mbps when it needs it. With that in mind, what exactly do you mean by it being inconsistent? And what's your total bandwidth speed?
- FURRYe38Nov 08, 2018Guru - Experienced User
Be sure your speed testing with a wired PC as well. Speedtest results on game consoles are known to be not as accurate and wired PC testing.
