bcj020
Nov 17, 2019Tutor
Nighthawk wireless router
IT PEOPLE, NEED HELP!!!! I have a Nighthawk wireless router that I am having issues connecting to with Ring doorbell, Nest learning thermostat and Blink camera system. Everything else is connecting w/...
bcj020
Nov 17, 2019Tutor
I have already tried that. Still doesn’t work.
Netduma-Fraser
Nov 17, 2019NetDuma Partner
What router model are you using? Disable QoS completely as it may be interfering. Also you say issues connecting to the WiFi - could you clarify? Does it connect but there is not internet access? Does it fail to even join the network?
- bcj020Nov 17, 2019TutorI am using the XR500 Pro Gaming router. The router lights show that the 2.4GHz, 5GHz power and internet are all running as if they should be. I am having no issues connecting to the internet via phone, computer, Amazon Alexa, XBox One but when I try to connect my Ring video doorbell, Blink camera system or Nest products (smart thermostat and Nest protect) it is having issues establishing an internet connection and keeps telling me there was a problem with the internet. If I connect these devices to my old router (also Netgear) or via mobile hotspot, they connect right away. I’ve never had this issue happen to me before and I am literally at a loss. I have tried everything that I can think of to include factory resetting the router.
