bcj020
Nov 17, 2019Tutor
Nighthawk wireless router
IT PEOPLE, NEED HELP!!!! I have a Nighthawk wireless router that I am having issues connecting to with Ring doorbell, Nest learning thermostat and Blink camera system. Everything else is connecting w/...
Nov 17, 2019Guru - Experienced User
Are you using the same SSID name and PW as your prior router? You can.
Try disabling Smart Connect on the XR router.
- Netduma-FraserNov 17, 2019NetDuma PartnerDid you try with QoS disabled from the Anti-Bufferbloat menu? Try creating a guest wifi network and connecting them to that and see if it works.
- bcj020Nov 17, 2019TutorI will try this...have not tried it yet.
- bcj020Nov 17, 2019TutorDifferent SSID and password. I’ve already disabled the SmartConnect, still having the issues.
