Recons
Feb 24, 2020Initiate
Nighthawk x10 R9000
I recently upgraded the Router Firmware Version V1.0.5.8 and both my WiFi 2.4 and 5ghz have gone away, I'm not sure what happened, my LAN works but my WiFi went away, I can't connect my smart tv or ...
May 26, 2020Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
Recons wrote:I recently upgraded the Router Firmware Version
V1.0.5.8 and both my WiFi 2.4 and 5ghz have gone away, I'm not sure what happened, my LAN works but my WiFi went away, I can't connect my smart tv or my phones, the SSID also went away, not sure what happened, is there a fix for it?
