ScottyB45
Sep 20, 2019Aspirant
Nighthawk X10 VOIP/IP capable?????
Hi all, Appreciate this is a gaming section but as it's Nighthawk specific thought I'd give it a spin anyway. New house build has fibre to the property which is great but has caused a few headaches...
Sep 20, 2019Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
ScottyB45 wrote:Hi all,
New house build has fibre to the property which is great but has caused a few headaches with simple needs I have for my home business; one of which is basic telephony. Just got off the phone with my ISP who rekon the X10 does not support VOIP....quick google search not shedding much light and my Netgear support apparently now expired so thought I'd try the community as suggested. I can see a load of info on confirmed capabilities of earlier models but not keen to go "back", or worse still use the box standard router provided by my ISP.
Anyone have the definitive answer? Appreciate any contribution.
Scott.
ScottyB45
Thanks Furrye38.
