maccman23
Jul 10, 2021Aspirant
Nighthawk x500
My nighthawk router just dies while rebooting and I can’t connect to it. I have a virgin cable router that I was using in modem mode and the nighthawk as a router. I’ve had to switch the virgin modem ...
Jul 11, 2021Guru - Experienced User
You have the XR500?
What actual firmware is on it?
What actually happens. You put it dies. Does the led's run through a cycle, are all the led's on and solid, can you ping it?
You've put what you've tried but not what the router is doing/results your getting
