maccman23
Jul 10, 2021Aspirant
Nighthawk x500
My nighthawk router just dies while rebooting and I can’t connect to it. I have a virgin cable router that I was using in modem mode and the nighthawk as a router. I’ve had to switch the virgin modem ...
Netduma-Fraser
Jul 13, 2021NetDuma Partner
As above, could you explain a bit more about what exactly happens? How are you rebooting it, pulling the power, using the button or via the interface?
- maccman23Jul 13, 2021AspirantHi thanks for your replies. I’ve realised it was a typo. It died. I rebooted it using the interface but it froze and the interface screen went blank white. I’ve tried plugging it in directly with Ethernet to my laptop and trying both router login.net and 192.168.1.1. But I’ve not been able to get it to the interface screen since. I might be doing something wrong in the way I’m connecting it. When it switches on one red light comes on but that’s possibly because it’s not connected to the modem. I use my virgin media router as a modem and the x500 as a router. Haven’t had a single problem with it before, signal is really strong. I’m not a gamer but my son is and he says it’s never dropped out and he’s on the second floor of the house. Warranty has expired but I don’t want to give up on it especially as it was £250 and worth every penny until this happened. I It’s disconnected and I’ve switched my virgin router to router mode for now. I’m just at a loss what to do. I tried a factory reset but no joy. There’s probably something I’m doing in the sequence of trying to get it going and my son now lives 300 miles away ( ironically as IT support) and he’s not back till august. Any suggestions welcome
- Netduma-FraserJul 13, 2021NetDuma PartnerHold the reset button for 30 seconds, release, wait 2 minutes then try to connect to the interface using 192.168.1.1 and see whether that gives you access
- maccman23Sep 13, 2021AspirantThanks I am going to try again from scratch. My original setup was the virgin hub as a modem then the x500 went into reboot and then just stopped working. I’ve reset it but because I work from home, I need to do it at the weekend. Just to make sure I’m getting it right. I switch the hub into modem mode the from port one into the yellow port on the nighthawk and then plug an Ethernet from my MacBook Pro to the nighthawk ? My son set it up originally and he has moved away. After I did the factory reset all lights are white so I want to get it up and running again. Had it over two years without a problem. Immense signal. I also want to update the firmware for my access point but that’s another topic. Thanks for the advice
