Alexpapa413
Sep 09, 2019Follower
Nighthawk x6 ac3200 power fail? Router won’t stay on
Please help, my router won’t stay on. When I turn it back on manually or power back up it flashes Amber in the power section, then all the other lights flash white fast and slowly start to dim out aft...
Sep 10, 2019Guru - Experienced User
I take it you meant the R8000? ac3200 isn't a model number.
What firmware is on it?
How old is it?
Do you have any way of checking the power supply? (aka multimeter)
