Alexpapa413
Sep 09, 2019Follower
Nighthawk x6 ac3200 power fail? Router won’t stay on
Please help, my router won’t stay on. When I turn it back on manually or power back up it flashes Amber in the power section, then all the other lights flash white fast and slowly start to dim out aft...
Sep 10, 2019Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
Alexpapa413 wrote:
Please help, my router won’t stay on. When I turn it back on manually or power back up it flashes Amber in the power section, then all the other lights flash white fast and slowly start to dim out after about ten flashs.
Any info appreciate
