Joshuan
Dec 17, 2019Aspirant
Nighthawk X6 R8000 - Speed Test Much Slower Than When Connected to Modem
Please help. I have had this router for a few years, and recently I started to have two separate issues. Issue 1: After my desktop is connected to wifi for an extended period of time, I start to g...
- Dec 20, 2019
Joshuan wrote:Just to let you know, I went to the older firmware, and I updated the driver on my network card. I am not experiencing issue one; however, the download speed is still about 300 Mbps. Additionally, I plugged my laptop directly into my laptop and fast.com showed that it was receiving a speed of 950 Mbps. So, I am pretty sure that something is going on with the wireless signal.
-Josh
Not really. Wireless speeds aren't going to be as fast as wired. And a lot depends on the device you're using. If you're laptop/phone is a 1x1 or 2x2 antenna arrangement, its going to be slower. Plus it'll be significantly slower on 2.4ghz versus 5ghz. The realtek is a 2x2 and isn't that great of a card in the first place.
If you're pulling the full speeds from the router while wired, thats to be expected. Wireless isn't going to hit that currently. Even the newer AX routers connected to a wireless AX card *might* be able to max out gigabit. There's a lot more info at this site on wifi speeds, expectations, and cutting through all the marketing hype by router manufacturers:
https://www.duckware.com/tech/wifi-in-the-us.html
the vast majority of the time the limiting factor to wireless (if you have a decent enough router) is the wireless device itself.
Joshuan
Dec 18, 2019Aspirant
Thank you so much for responding to my post! I really appreciate it.
1. I am using a Motorola MB8600
2. I added a pciture... Is that the right information that you wanted? If not, let me know. I will put up the new info as soon as you ask for it.
3. V1.0.4.46_10.1.63
4. My wireless card is a Realtek 8822BE Wireless LAN 802.11 ac PCI-E NIC
Let me know if you need ANYTHING else.
Dec 19, 2019Guru - Experienced User
I linked to what netgear's modem connections page looks like. Not sure what it'd look like on the motorola. Its shows the coax connections strengths to the modem.
In terms of the router firmware, the version you're on is the firmware that netgear updated their routers to netgear Armor. many devices had a degradation of speeds. Many were resolved with a factory reset and manual reinstall (not using a backup). If that doesn't work, downgrade the firmware to a version before Armor. Make sure to do it over a hardwired connection and to reset afterwards.
You desktop wifi issues might be the card itself. If you look up that wifi card, its got a bunch of issues. Occasionally a firmware update from the manufacturer helps but many people just replace them.
- JoshuanDec 19, 2019Aspirant
Yeah, I clicked on literally every link on that routerlogin.net page, and I cannot for the life of me find the information you are requesting. I don't think that the issue is the wifi card on my desktop because I have two separate laptops that behave the same way with the speed issue (the lag issue maybe).
-Josh
- plemansDec 20, 2019Guru - Experienced User
-Josh
