chalaph
Dec 10, 2018Aspirant
Nighthawk X6 vs XR500
I currently have the Nighthawk X6 AC3200. I live in a rural location and my internet download speed is most often around 12 mbbs. This is the best I am getting w/ a 50 mbps service currently. This is...
Dec 10, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
