chalaph
Dec 10, 2018Aspirant
Nighthawk X6 vs XR500
I currently have the Nighthawk X6 AC3200. I live in a rural location and my internet download speed is most often around 12 mbbs. This is the best I am getting w/ a 50 mbps service currently. This is...
Dec 10, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Netduma_Jack
Dec 11, 2018NetDuma Partner
Hi there,
Compared to the X6, the hardware on both routers is great. The difference is DumaOS, which powers the XR500 and XR700, and it has many unique features that will get you the best connection possible.
Because your bandwidth speeds are not that high, you will really benefit from QoS. It lets you allocate bandwidth to your favourite devices (i.e. gaming) and also makes sure nothing in your home can use all your bandwidth, which causes lag.
The Geo-Filter is also amazing if you play a game where you cannot control the server you play on e.g. Black Ops 4, Fortnite etc.
I recommend you check out the features here: https://netduma.com/features/
NETGEAR also have some good videos on their channel which show the main features off:
https://www.youtube.com/watch?v=DzPWRTMgZM0
https://www.youtube.com/watch?v=0IZ09fTwrzs
