Svylas
Sep 23, 2018Follower
Nighthawk XR 500 Connection Drops
Hi there.
My routers product name was not listed in in the model bar above for some reason so please go by the title instead. I'll also list my router below.
Just purchased this route...
michaelkenward
Sep 24, 2018Guru - Experienced User
That's because you have posted your message in the section of this community given over to Nighthawk WiFi Routers.
Netgear bills your devices as a Nighthawk Pro Gaming Router.
You might get better replies, and find other answers, over in the appropriate section:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Svylas wrote:
It's got the latest firmware upgrade as I just checked for it
Two things, where did you check? The on-board test is less reliable than checking the support pages.
There is support for the XR500 at the end of this link:
>>>XR500 | Product | Support | NETGEAR<<<
Secondly, did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
xnsys
Sep 24, 2018Luminary
The same issue that's plaguing the majority of the Netgear range.
My advice, take it back, get your money back, and buy something better.
- Netduma-FraserSep 25, 2018NetDuma PartnerThis is something we're aware of and investigating so there will be a fix. We suspect its to do with Instant On/Automatic Updates on a console. Could you switch these off on your console or if PS4 shut down fully and see if this resolves your issue please.
