Svylas
Sep 23, 2018Follower
Nighthawk XR 500 Connection Drops
Hi there.
My routers product name was not listed in in the model bar above for some reason so please go by the title instead. I'll also list my router below.
Just purchased this route...
xnsys
Sep 24, 2018Luminary
The same issue that's plaguing the majority of the Netgear range.
My advice, take it back, get your money back, and buy something better.
Netduma-Fraser
Sep 25, 2018NetDuma Partner
This is something we're aware of and investigating so there will be a fix. We suspect its to do with Instant On/Automatic Updates on a console. Could you switch these off on your console or if PS4 shut down fully and see if this resolves your issue please.
