Pippen1410's avatar
Mar 01, 2018
NightHawk Xr 500 pro gaming
Hello forum i’m From Greece and I have problem with distance 1000km to find games and I want best setting for ps4 pro for call of duty ww2!!
1 Reply
  • Hi Pippen,
    Click "Profiles" on the right hand side of the map. Then select Call of Duty. This will use our recommended settings for Call of Duty on the Geo-Filter. It will expand your radius, you should then have no issues getting a game within your radius.
    Then for the QoS page on Anti-Bufferbloat select 'Always'. Then give both the download and upload sliders 70% each. This will ensure that you dont get any local congestion. So that you have the best connection possible when gaming.
    Also under Traffic Prioritization ensure DumaOS Classified Games is enabled. This will prioritize your games console.
