Chelseanick25
Jun 22, 2018Guide
NightHawk Xr 500 pro gaming
Hi guys and gals, I’m pulling my hair out here.Ive spent a fortune on this router but can’t get it working at all.Im probably not as clued up as you guys so be kind I really need help. I’m vdsl fibr...
Netduma_Jack
Jun 22, 2018NetDuma Partner
Does your modem need PPoE? Which means, do you need to enter credentials like a username and password?
If so, make sure you do this on the router?
If you connect directly to your BT hub, do you get Internet?
