Chelseanick25
Jun 22, 2018Guide
NightHawk Xr 500 pro gaming
Hi guys and gals, I’m pulling my hair out here.Ive spent a fortune on this router but can’t get it working at all.Im probably not as clued up as you guys so be kind I really need help. I’m vdsl fibr...
Killhippie
Jun 23, 2018Prodigy
Did you do the internet setup? On wifi untick the box and it will seperate the wifi into two SSID's
Chelseanick25
Jun 23, 2018Guide
Unchecked the box and set names to channels and passwords,done.now I’m stuck spinning on personalise your router.both channels I created are there.with a spinning circle below.
